Diesel Forum - TheDieselStop.com - View Single Post - Help! 2001 Ford F250 Lift with vibration
Old 11-01-2009, 07:48 PM   #5 (permalink)
stinger254
I spaced the carrier bearing more today,but it didn't matter what I did It didn't even help. So I pulled the blocks in the rear and left the Front raised and it still vibrates like it is coming thru the drivetrain down the center of the truck. After I did that I pulled the rear driveshaft between the carrier bearing and rear axle and put it in put the truck in 4wd and no vibration. So the vibs have got to be coming from the carrier bearing back. The good thing is that it uliminated the front shaft, transfer case, trans and every thing up front. So that's where I am at now. I am going to take that shaft to get checked out tommorow. I doubt it is the driveshaft but it is cheaper to get it checked out than to look at the rear end right now. This truck is really starting to pi$$ me off. ANY MORE IDEAS?
stinger254 is offline   Reply With Quote
