Originally Posted by Jared583
so my buddy just bought a 2004 F-350 6.0 with 116,xxx miles on it, the truck seems to run really good and everything seems to work fine, but it does something I've never seen before. So when you turn the key on when it's cold you can hear the glow plugs and injectors and what not under the hood, which is normal but after running it he shuts the key off and you can hear the same noise after it shuts off. it runs for approx 30 seconds with no key in the ignition. any ideas?
Turn it off in gear if its automatic transmission until a mechanic can determine the problem.
