Diesel Forum - TheDieselStop.com - View Single Post - Camper control problems
Old 11-01-2009, 09:15 PM   #3 (permalink)
dacriss
My Photos: (12)
Same, same, same
I have the same camper and basicly the same truck (except you have heavior spring packs). What tires are you running now? Look at my pics and I believe I have some of truck and camper. I went with a 4" lift, 35x12.5x18 toyo mud train tires 8 ply. These tires have a very heavy side wall to them. Also having 18 inch rim deceases the side wall and the less side wall you have the less sway you will have; however, the bumpier the ride will be unloaded. I also run air bags to counter the weight of the camper. The wider tread contact also helps. The stock sway bars seem to work fine for the way I have it set up. But the 4" lift (2" more in the rear) means you have to lift the camper higher to get it loaded.
DACriss
'99 F250 SD,XLT,PSD,4X4,6spd,3:73,LB, SRW, Steel Horse billet grille, Catch all floor mats,VDO vision boost-EGT-OST dash pod,Mongoose CB, Luk flywheel, Carolina P-plate and Kevlar disc, Built 10/98, received mid Dec., Edge 4.5 lift, Adj. Pan-Rod, Bilstein Shocks,35-12.5x18 Toyo m/T on MKW MK19 10x18 wheels, AFE stage-2 intake,KCM S.S. High Pressure Crossover Kit, '03 TT mirror convertion, '03 AM/FM 6-disk radio, billet thermostat housing w/203* stat, Coolant filter, Evans coolant, Heater/A-C mod., SSBC V8 brake calipers, slotted rotors, custom dual steering stabilizer w/Fox Shocks, Blue Torch front diff cover
dacriss is offline   Reply With Quote
