11-01-2009, 09:36 PM
#5 (permalink)
Not a bad idea - a piece of cardboard and some wire ties would do the trick if needed.
Originally Posted by Hunter40
I have to agree with rock doctor. Seems like a waste of 80 bucks if you're just passing through. My neighbor bought a new tv and I cut the box to be a little smaller than the grille. The box fits right behind the grille and even in the worst snow storms I haven't had a problem. Because I'm also a little vain, I spray painted the front facing side of the box so it's not even noticeable when it's in place. Sure beats the look of the big winter grille cover.
My$.02
Hunter40
2008 F250 XL Crew cab, manual 4x4, 6.4L, Job 3, TorqueShift, w/ Decor group, Camper Pkg, Off Road Pkg, LWB, Power Equipment Group, Tow Command, Knapheide Utility Bed with sliding top. Built 2/5/2008 & Purchased 9-1-08
08B07 Flash 1-16-09
Firestone Ride Rite Air Springs 3-20-09
Radiator (end cap leak) @ 34,100 miles 11-19-09
11B23 PCM Recalibration 4-11-11
Hydroboost Replacement (leaking Power Steering Fluid) @ 82,866 miles 7/25/11
Upper & Lower Hoses (new design) @ 90,000 miles 11/10/11
