Diesel Forum - TheDieselStop.com - View Single Post - Obtaining Winter Grill Cover
Old 11-01-2009, 09:38 PM   #6 (permalink)
compman72
compman72's Avatar
My Photos: (9)
Snow packing of air filter/air induction:
If snow obstructs the air induction/air filter on the 2008 F-SuperDuty, there is a winter grill cover available to correct this problem. The cover is a customer purchase item, and must be installed as per the included instructions. The cover should be removed in temperatures above 50 degrees for normal driving, or 32 degrees when towing. Symptoms include a lack of power under acceleration and resticted air filter lamp illumination. Part number 8C34-19A413-AA. Broadcast Message 0284, 7323.
Originally Posted by 444-4D View Post
Why do you need to cover your grill?
2008 F250 XL Crew cab, manual 4x4, 6.4L, Job 3, TorqueShift, w/ Decor group, Camper Pkg, Off Road Pkg, LWB, Power Equipment Group, Tow Command, Knapheide Utility Bed with sliding top. Built 2/5/2008 & Purchased 9-1-08
08B07 Flash 1-16-09
Firestone Ride Rite Air Springs 3-20-09
Radiator (end cap leak) @ 34,100 miles 11-19-09
11B23 PCM Recalibration 4-11-11
Hydroboost Replacement (leaking Power Steering Fluid) @ 82,866 miles 7/25/11
Upper & Lower Hoses (new design) @ 90,000 miles 11/10/11
compman72 is offline   Reply With Quote
