swamps diesel. the original post was from powerstroke nation. it gives a great post on diagnotics for a bad ficm. and heat is not the main killer. it is the heat flash that would pump out 48 volts for up to 2or 3 minutes that caused the boards to overheat since they were designed for short bursts not long ones. swamps also offers a upgrade to up the voltage to 58 volts which is a popular mod on the older 7.3 idms that helps with starting and idling. very good post that all should read.
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
