Originally Posted by '08 F350 FX4
How does snow blowing in from the grill make it all the way back to the air filter which is located in front of the passenger side of the firewall (am I correct on this location?)?
You have obviously not spent much time where it's really cold and snowy.
Snow is still snow till the temp gets up above 32F, and since the engine is sucking in cold (below freezing) air, the filter isn't much warmer than what's coming in the grille. So the snow acts just like dirt, only it stays suspended in the air longer because it's less dense than dirt, and plugs the filter, posthaste.
I think you can get a cold front from Alaska Tent & Tarp in Anchorage for $40 or less.
Winter Fronts from Alaska Tent and Tarp
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version
), AIS,
coolant filter w/"hokum" bracket, regulated return,
heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
