Diesel Forum - TheDieselStop.com - View Single Post - Cam Position Sensor Bad?
Old 11-02-2009, 08:13 AM   #7 (permalink)
JimmyRice
Sorry for not responding sooner, but NO, I had no codes at all. According to the scanner, everything is just fine. And so you know, though changing the CPS did not turn out to be all that hard, it did not change anything. As our weather here in Colorado gets colder, it seems to me I have no problems if the outside air temp is below 40. If it's above 40, then I start to have the idling and surging problems. Like you, particularly when off the throttle like at a stop light, going down hill, pulling into a parking lot, etc. Hope this helps. Good luck.
96 F-250 7.3 L PSD, Super Cab 4x4. 6in Super Lift. 210K and going strong.
2004 F-350 6L 4x4, CC, DRW, 4.10 LS rear, ESOF, Westin Chrome & SS Brush Guard, Reese 16K hitch in bed, Fumoto valve, Air Lift airbags on the rear. OIF 03-04 and 05-07. Our troops are doing a great job. HOOAH!
JimmyRice is offline   Reply With Quote
