You need both. You need the connection to the PTO enable / request line to enable the SEIC mode, and you need the resistor to set the desired idle RPM if you want something other than the 1,200 RPM default.
[IMG]file:///C:/Users/ts01729/AppData/Local/Temp/moz-screenshot.jpg[/IMG]
