Diesel Forum - TheDieselStop.com - View Single Post - Disconnecting power to the EGR valve solenoid Will it hurt anything?
Old 11-02-2009, 11:39 AM   #18 (permalink)
blizzardwarrior7
My Photos: (6)
Send a message via AIM to blizzardwarrior7
By unplugging the EGR valve, are you preventing the exhaust gasses from entering the engine to be reburned? It seems to me, if you were you would have a power increase due to more oxygenated air being able to fill up the cylinders.
2006 F250 cc/sb sct, studs egr delete, 100 shot injectors, fass fuel pump, twins, rough country 4-link 8" Lift, 38"x15.5" Dick Cepeks, 20x12 Rockstars, 4" Dual Exhaust, Ranch hand bumpers Front & Rear
2002 F350 XL RC/LB Pro Comp 6.5" Lift, 37"x13.5" SuperSwamper M16s, Stage II's, GTP38 turbo, DP Tuner, AFE intake, 5" exhaust, JW Slush Box, AIH Delete, CCV Mod, Zoodad mod, 5.6k mod, FPR Shim, ATS Flex Plate, ATS Torque Converter, AirDog FP-150, Fluidampr.
2006 Ram 2500 QC/SB Smarty, 5" straight pipe, edge, Leveling kit, 35x13.5" mickey ATZs
2006 International CXT DT466 300 hp 860 tq Diablo powerpuck, 6" straight pipe into 7" single stack
blizzardwarrior7 is offline   Reply With Quote
