Diesel Forum - TheDieselStop.com - View Single Post - Need a spring expert.
Old 11-02-2009, 11:40 AM   #2 (permalink)
boomboom
boomboom's Avatar
With my X-codes my front wheel well measures 40" from the ground with 285x75x16 tires ( 32 1/2 diameter ) You can take that measurment to your truck and estimate where yours would sit with X-codes. My rear wheel well sits at 41" with the F-350 rear blocks which are 3 1/2" + and I sit pretty level, but I'm not sure if a truck rear wheel well is the same as an Excursion though . X-code front spring part # 2C3Z-5310-AF and I do NOT have any lean at all after 6 yrs of having these springs on. But I am no expert this is just my experiance.
boomboom is offline   Reply With Quote
