Diesel Forum - TheDieselStop.com - View Single Post - autometer guages not working
Old 11-02-2009, 12:08 PM   #12 (permalink)
ckanderson
ckanderson's Avatar
Originally Posted by Matt0987 View Post
I wonder if that is true. My Outlook on my F350 shows 2 Pounds when the engine is off. I was told that is normal. I wonder if it is not uncommon for there to be a residual pressure in the system. At least in a tight system. Depending on where in the system the sensor is located. You know, in a system that does not have any leaks.
its not normal. their is no residual pressure in the engine.
i was using the guage on a gasser and 3-4 psi was a HUGE increase when i was only running 15 psi.
2002 F-250 7.3 4x4
1964 Nova 400 w/350
ckanderson is offline   Reply With Quote
