Diesel Forum - TheDieselStop.com - View Single Post - Disconnecting power to the EGR valve solenoid Will it hurt anything?
Old 11-02-2009, 01:48 PM   #19 (permalink)
da-bees
As has already been stated,not reccommending that anyone disable the EGR. With that clear,I like this decussion because it explores an area that has not recieved enough attention previously. So let's talk farthur,and who knows,when and "if" regulations are relaxed,we know what if any benefit could be realized by simply stopping exhust flow at exit side of cooler as apposed to at the up-pipe. IMHO,I think it might add sugniffent life to the cooler because it would have to disapate less heat with the reduced amount of coolant that the partialy plugged oil cooler allows. The results would undoubtly be closly related to the eot & ect differince at the time action is taken. On a related note,I believe these engines needed a coolant filter or a clean block from the beginning ,or as soon as you can install it regardless of what else is done. Any other comments?
2004 F250 CC 6.0 PS , no mods
da-bees is offline   Reply With Quote
