Diesel Forum - TheDieselStop.com - View Single Post - Do I replace the oil cooler
Old 11-02-2009, 01:56 PM   #3 (permalink)
boomboom
boomboom's Avatar
Originally Posted by RXCRAWLER View Post
I tried searching for this answer but didn't find it.
I'm about to fix the EGR and install a coolant filtration system. Do I need to replace the oil cooler while the truck is apart or will the coolant filter eventually clean out the gunk that is already in the oil cooler?
The gunk in the oil cooler that is there will remain there even with coolant filter installed. I would replace it sense you are allready there and make sure you flush engine block and radiator REAL good so you start fresh and clean even with filter in place.I dont think you can clean the oil cooler but not 100 % sure on that. But if you don't it could come back and HAUNT you later.
boomboom is offline   Reply With Quote
