That nut vibrated off and it came apart. With the miles You have on it and since your down there i would probably put new orings on it for the piece of mind.
I would also suck the hpop reservoir dry or the valley will be full of oil. Not necessary but a good idea
The solenoid and spacer slide on that shaft then the nut tightens it down snug, not too tight. When together should look like the last half my posted pic.
Good luck joe, hope it goes smooth.... Your welcome buddy
97 F250 HD 7.3L 4x4 165,000 Mods: 6637 Filter, Poly front bushings, 3" Downpipe, Lost Kitty
