Diesel Forum - TheDieselStop.com - View Single Post - Disconnecting power to the EGR valve solenoid Will it hurt anything?
Old 11-02-2009, 02:57 PM   #20 (permalink)
johnny87
Originally Posted by teamroper60 View Post
Maybe, maybe not... You definitely do for the most efficient burn. But, with the headbolt setup on the 6.0, you have to be careful, since higher heat/more complete burn will lead to higher cylinder pressures and those higher cylinder pressures can cause blown headgaskets....
The thing is, we know that removing it increases cylinder pressures but we don't really know how much. Without knowing how much, we don't know if removing it has a significant negative impact on headgaskets or not........
Exhaust gas recirculation lowers combustion temperatures to reduce the formation of nitrous oxides(NOx) not to protect the head gaskets from blowing. The process is intentionally inefficient for the sake of emissions. The introduction of a fresh air charge helps to remove heat and control cylinder temperatures otherwise(in lieu of EGR)
read this...
Southwest Labs EGR Diesel III | Centron Energy Corporation
2007 F350 XLT 4x4 SC 6.0 PSD No Mods *Traded*
2011 F250 XLT/FX4 4X4 CC 6.7L PSD
johnny87 is offline   Reply With Quote
