Ron,
I have run into the same problem with Hayden for another application, same symtoms as the second unit you installed. I warrantied a couple of them before finally getting one that worked OK out of the box but went to the prolonged lock up on cold start you described. About that time I dropped down to about 1000 miles a year (cattle truck) and quit worrying about it. It is still doing it 5 yrs later.......
Diesel Mechanic 28 yrs
