Originally Posted by steveb19
Hi
Our E450 Super Duty has a 6 Litre Powerstroke diesel with no aftermarket mods. On its first long trip to with 5800 miles total on the clock the engine has failed terminally. From what the engineers have seen without stripping it down it appears to have had a piston failure and oil pan fire. I have contacted Fords countless times and although they have admitted I have a valid warranty they are being evasive. I've since found out that Fords had major problems with this engine. Anyone else had problems that can advise me on how to proceed?
Steve
This post smells fishy......
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Draw Tite Fold Over Gooseneck * Reese 15K Sliding 5er * Gauges Whited Out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics * Walbro GLS392 * Ford AICM * ITP Pre-pump * One Very Understanding Wife*
I AM AN AMERICAN, SO I DRIVE AMERICAN.
