I got mine for my Ex. and as such I would not be pulling a 5th wheel.
They install under the bumper stops which are located over the axle. I am not sure where they install in a pickup. Probably similarly.
You can go to Air Lift's website and download the install instructions. That is what I did so I was familiar with the install before the bags arrived.
Since the 5th wheel installs over the axle would the likelihood if a broken frame be pretty minute? If the 5th wheel was installed behind, or in front of, the axle I could see pressures on the frame increasing as the the 5th wheel is moved away from the load bearing location of over the axle.
I would think that you would need to install some sort of extention or "drop" to make up the difference for the lift.
The helper springs may be the way to go, or a complete set of springs, if you used the truck only for pulling the 5th wheel. But there is an advantage of being able to air down the bags when using the truck for everyday driving.
I got mine from;
Airlift Loadlifter 5000 Series
A couple of other sites you might want to consider;
2004 Ford F-350 Air Lift Leveling Kits
Vehicle Search
'03 Excursion, 7.3L, 4X4, Auto tranny of course (they all did), 4" MBRP exhaust, TS performance chip, K&N FIPK w/ an Amsoil EA filter, Hellwig anti-sway bar, drilled/slotted front & rear rotors. Rancho XL shocks, Rancho steering damper, Airlift 5000, S&S Diversified headlight mod. This baby surprises a lot of, so called, performance cars.
'04 F 350, extended cab, 6.0L, FX4, manual tranny, 4" MBRP exhaust, Bully Dog Triple Dog downloader w/ Outlook moniter (Very disappointed in the Bully Dog), 2m-70cm Yaesu ft-8500, S&S Diversified headlight mod.
'11 Harley-Davidson Road King Classic 103 ci PowerPak w/ anti lock brakes & Smart Security system. It even has cruise control!!! Candy Dark Root Beer over Candy Light Root Beer  Yaesu FTM-10R & a Comet CSB 790A
