Diesel Forum - TheDieselStop.com - View Single Post - FIPL adjustment
Thread: FIPL adjustment
Old 11-02-2009, 05:29 PM   #20 (permalink)
Kevin 007
Kevin 007's Avatar
I appreciate you time!! My gear/sensor unit on the end of the speedo cable that plugs into the transfer case is new, the transfer case was just swapped in two months ago...I wish I pulled the tail housing to replace the gear at that time. But still, its a low mileage t-case and the old 350,000mile t-case had no issues with the speedo. Ive swapped on some different used gears at the end of speedo cable to no avail.
I guess im going to be pulling that t-case again....
How about the VSS? does it have anything to do with it? its new also.
And to snotzalot...I have checked the brake switch and monitored the brake lights closely and everything seems to be functioning properly.
1984 F-250 6.9, T-19, BW1345, D70 rear end. solid truck.
1984 toyota BJ60 Landcruiser, 3B diesel, H55f 5 speed, Best rig Ive ever owned. Never needs anything, 503,000km, Old Man Emu suspension, rusty and running strong Will certainly outlive all my other wheels
1985 Toyota 4wd pickup, single cab, rare 2lt 2.4l turbo diesel, 5 speed, custom flatdeck, timing belt every 100,000k and shes good to go. 393,000km Excellent fuel economy!
1983 Mercedes 300d, low mileage.....gorgeous!
Kevin 007 is online now   Reply With Quote
