I doubt that the oil cooler getting plugged would cause a no-start, although it may be leaking.
If it's leaking coolant into the cylinders (head gasket or cylinder wall perforation from cavitation), then it might be hydrauliced (cylinder full of incompressible fluid).
But the curl of smoke rising from the area between the battery and PS compressor would make me closely inspect the battery cables for interior corrosion. It may be that they're not wire anymore, but green goo inside the insulation.
Good luck with it.
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version  ), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
