I have found that on my AIS I was also sucking in the air-meter thingy on the airfilter box (both the new one that came with the kit and the original one that came with the truck) anytime I went WOT or pushed it hard. The solution was to simply remove the long snorkel piece. Just looking at it you can see how reduced it is in comparison to the filter box's opening. Now I can't pull in the filter-minder thingy. I live in a dusty area and it keeps the intake tube nice and clean. Works really good, but you do need to either remove the front snorkel section on it and/or do the fender sleeve mod to really let the AIS breathe. My 2 cents worth.
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, custom bed carpet/bench inserts, Rhino grill guard, Bugshield, mud flaps, CCV Mod, AIS w/foam sleeve, Fuel filler mod, GOS headlight harness, Hella 80/100s, 02-04 Headlights, Rancho HD steering stabilizer, C-Btr Mirrors, Hella FF1000, Sonnax/Tricumulator, Htr Bypass valve, 31 row 6.0 tranny cooler,front receiver hitch, Quadzilla XZT gauges, ITP Pre-pump/In-tank mods, Pioneer P5000UB w/XM radio, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX, IDM mod, DP F5 (Stock,Drive-thru,60T,80E,120,80E-Mountain,1200), Walker BTM, RR, Dieselsite BRV
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DTRS and BPP kill switches, DIY "pitstop" switch.
http://community.webshots.com/user/l...host=community
