Cary,
Any plans on when you will be releasing the longer trac bar? I always felt it was awfully short and probably binds up the front suspension in extreme articulation. Plus the bump steer issue.
While we are at it, any word on the front transfer case yokes?
What ever became of the billet OBS thermostat housing project?
Diesel Mechanic 28 yrs
