Originally Posted by Cool_Canuck
The bolts may not have been installed correctly. The bolt's are suppose to be installed so the grease holes are horizontal. Do not over tighten the bolts.
Thank you for the info guys, i will try. They are a pain to turn, as they are barbed so i will try to mess with them some more.
What disc are you referring to a couple of posts pack?
2002 F350 Lariat CC SRW 4x4 LB , Shadow Gray, Edge 4.5" w/ dual bilsteins up front/ Toyo Open Country M/T 315-75-16. Stock Motor 7.3, dual alts / 3 guage pillar pod, Auto Meter/ 5" turbo back magnaflow exhaust w/Aeroturbine muffler & 6" Jardine tip/ Husky 24k 5th wheel / Air Lift Bags.
John Wood Transmission / DP tuner / 08' rear diff cover
2005 40' Weekend Warrior 5er, SLC 3905
1977 Tahiti 21' / Berkeley Jet Daycruiser/ 455 Olds.
2000 Sandcars Unlimited / Turbo VW 2275
1988 Ford Thunderbird Turbocoupe 2.3
