Originally Posted by johnny87
Exhaust gas recirculation lowers combustion temperatures to reduce the formation of nitrous oxides(NOx) not to protect the head gaskets from blowing.
That is true. However a side effect of lowering the combustion temperatures
IS lower cylinder pressures. Another side effect of using EGR is that timing must be increased due to the slower burn.
So, if you increase the combustion temps and you will also raise cylinder pressure. In addition, with the cleaner, quicker burn, the timing will also be increased. Increased timing also raises cylinder pressures. So you are effectively raising cylinder pressures twice..
Again though, we don't know how much we are raising the pressures, so we don't fully know if the increase is enough to put the headgaskets in danger.....
Toreador Red/
Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03; AIC; Silverline turbo-back dual exhaust; 155cc injectors from Full Force Diesel (Casserly); SCT with tuning by Tony Wildman (Total Diesel Performance) & Innovative Diesel; ARP studs; Dfuser regulated return; AFE PG7; Fumoto valve; B&W hitch, Di-Pricol gauges; DIESELSITE Coolant filter; Timbrens; Rancho RSXs; Michelin XPS Traction's; a whole bunch of "bling"; Connex 4300hp; Pioneer DEH6100BT; JL Audio 275w amp driving a 12" sub; JL Audio 50wx4 amp driving the Alpine door and rear seat speakers. 380.3hp/786.7ft-lbs (on my tow tune!)
pics
#43
SLAPS President and Webmaster
