I did the same thing on my 08 one is hooked inside the cab to turn my review camera on whenever I choose. The other I hooked the upfitter power wire to a pass thru wire both are in the parkbrake area. Then caught the other end of the pass thru wire by the firewall on the drivers side and ran it to my box and used it to run some lights in the bed. Just hook the ground of whatever you want to run to the frame. Pretty simple. I think 2 of the switches are 10amp and 2 are 30amps but can't remember for sure.
