eating water pumps.
Any ideas for why I'm about to change the second water pump for leaking in the exact same place? I bought a reman water pump from napa. After a few months a leak developes by the t-stat. I am going to borrow my buddies psi tester to see exactly where the leak is. I have the 203 t-stat and the billet t-stat housing. I can't see any cracks or defects on the last pump to cause the leak.
2002 EX 4x2 Amsoil front to back with Amsoil oil bypass filtration, Cyclone Power fan, HX oil line, Dieselsite prepump and tank mods, local high performance transmission, MagHytec pans,MBRP 4" exhaust, AFE Stage II, BD EBV exhaust brake, Bright Box, Diesel Turbo Life Saver, Dieselsite 6pos. chip, Trans, EGT, Pyro and water temp gauges, Dieselsite tranny cooler, Dieselsite 203dg t-stat, Dieselsite AIH plug, rerout ccv, Coolant filter, Firestone Ride Rites, hellwig rear sway bar, Garrett BB turbo. Dieselsite hpop filter, Auto Enginuity program. Dieselsite Adrenaline hpop.
