Originally Posted by nashvillebill
I put the ConOFE clutch in, with its solid flywheel, and it hasn't been excessively noisy. There's only been a couple of times that I've noticed gear rollover; I usually don't rev it up in neutral.
I get a tad of gear noise at a steady speed in 5th gear, but I've had that since the truck was new. (I intend on putting some sound deadening material on the cab floor under the carpet next spring to get it even quieter)
That is one of the better conversion reviews I have read. Where did you buy that and how much did it set you back?
Thanks,
Larry
