Diesel Forum - TheDieselStop.com - View Single Post - helper bags
Thread: helper bags
Old 11-03-2009, 03:44 AM   #7 (permalink)
speeddemon31176
speeddemon31176's Avatar
Send a message via AIM to speeddemon31176 Send a message via Yahoo to speeddemon31176
I had a set of airlift bags on my old truck with a fifth wheel and had no trouble at all with it. I also had a 4" lift on the truck. The only problem I had was that the bags had to be aired up in order to get the studs on top of the bags through the holes in the mounting bracket due to the lift. Once they were bolted down all was good and that was for three years till i got rid of the truck. You can air the bags back down once installed too.
97 F-350 XLT CCLB 4X4,PSD
Gauges(boost/pyro) on triple pillar pod
CAI
IDM mod
4" DE turbo back catless exhaust
TS 6 pos. Chip
3" PA Body lift
ES body and suspension bushings/mounts
Extreme duty trans w/billet triple disc converter
B&M deep pan
Hayden "DAWG" trans cooler
Adrenaline HPOP
stage II's, D66, then custom tunes.
speeddemon31176 is offline   Reply With Quote
