The spring you are referring to is in another location inside the FPR. Don't worry about that right now. Yes that is the FPR bolt right by your knife blade. There is a little screen(you know the one) and a round plastic piece with a teeny hole in it and an o-ring on it and behind that is a teeny little plastic ball. If you are gonna dig in that far I would say to go ahead and take the bowl assembly out(two bolts and a couple of clamps and disconnect the harness on pass. side of fuel bowl). You might get lucky and find your little screen down in there. I found tons of stuff when I just changed out my bowl and FPR assembly. You can get the whole thing from Powerstroke Shop for $270.00.
97 F-350 XLT CCLB 4X4,PSD
Gauges(boost/pyro) on triple pillar pod
CAI
IDM mod
4" DE turbo back catless exhaust
TS 6 pos. Chip
3" PA Body lift
ES body and suspension bushings/mounts
Extreme duty trans w/billet triple disc converter
B&M deep pan
Hayden "DAWG" trans cooler
Adrenaline HPOP
stage II's, D66, then custom tunes.
