Just because a gauge reads something other then zero when not on doesn't neccesarily mean that the gauge is going to be inaccurate when its on. I've seen this so many time with factory and aftermarket gauges. Speedo's, tach's, fuel gauges, volts/amps sometimes the needles go where they want to until powered up. The boost gauge still bothers me though, does the gauge go to zero at idle or does it stay at 2 psi ??
