Originally Posted by speeddemon31176
The spring you are referring to is in another location inside the FPR. Don't worry about that right now. Yes that is the FPR bolt right by your knife blade. There is a little screen(you know the one) and a round plastic piece with a teeny hole in it and an o-ring on it and behind that is a teeny little plastic ball. If you are gonna dig in that far I would say to go ahead and take the bowl assembly out(two bolts and a couple of clamps and disconnect the harness on pass. side of fuel bowl). You might get lucky and find your little screen down in there. I found tons of stuff when I just changed out my bowl and FPR assembly. You can get the whole thing from Powerstroke Shop for $270.00.
THANKYOU......
After reading for a few hours it seems that I am only about the 439 person to have questions about this, wish there were more pics. I now realize that the "orfice vent kit" is the screen that a few people said I lost but it didn't look like the ones in the pics b/c I believe my screen is seperated from the white plastic part because I didn't see a ball either. I hope they stayed stuck in the fpr and the screen was seperated b/c it was in the hole in the bowl.
If the ball is missing would the truck even run????
If you were standing on the front bumper lookiing at the bowl naming the parts from left to right would it be.....
Fuel Bowl, screen, oring, ball fpr?? is that how it goes togeter
95 F450 7.3 ZF5 159k 12'PTO Dump, 3"DownPipe,
Tymar Intake & Coolent Filter, SB CON O, DIY Exh Brake.
95 2500 RCLB 251k, HTT 57/65/12, 191 DV, 5x.012 Injectors, 4KGSK, S&B Intake, 5in exh, 33x12.5x17's PC EMT, ProjectorHL w/6k HIDS, Goerend Tripple Disk Auto, 4 Isspro's
