Diesel Forum - TheDieselStop.com - View Single Post - oops #2
Thread: oops #2
Old 11-03-2009, 11:14 AM   #15 (permalink)
BuckshotRam
Hey Guys thanks for the help I, I can't blame you for not wanting to take apart yours, I don't really want to take mine back apart to see if there is a ball in it right now and not have the screen to put back in. Im pretty sure the plastic piece was attached to the fpr and the sceen must have become seperated over the years so Ill keep my fingers crossed that it is behind the white plastice piece that the sceen is attached to. Here's my game plan.
Order F5TZ-9A214-A Orifice Vent Kit is $13.78 from powerstrokeshop.com
When it gets here Im going to take the bowl apart and clean the screen in the bottom of the bowl and get the junk out the bottom of the bowl, if i get brave I might take it all the way off and go ahead and replace the rubber fuel lines. Then take the fpr loose and put the new screen and oring in and pray i find a ball there.
Fuel Pressure Regulator California Kit part number F6TZ-9K061-AA
FPR Kit Ford # F6TZ-9157-BA
What do these kits contain? I heard the Califonia Kit was about the same as shiming the spring (which I would like to do and there is another screen in the fpr that can be cleaned that I havn't messed with)
95 F450 7.3 ZF5 159k 12'PTO Dump, 3"DownPipe,
Tymar Intake & Coolent Filter, SB CON O, DIY Exh Brake.
95 2500 RCLB 251k, HTT 57/65/12, 191 DV, 5x.012 Injectors, 4KGSK, S&B Intake, 5in exh, 33x12.5x17's PC EMT, ProjectorHL w/6k HIDS, Goerend Tripple Disk Auto, 4 Isspro's
BuckshotRam is offline   Reply With Quote
