Diesel Forum - TheDieselStop.com - View Single Post - Long crank time to start truck. HPOP???
Old 11-03-2009, 12:35 PM   #2 (permalink)
DIESELSITE
DIESELSITE's Avatar
Do you have access to a scanner? If so, look at the IPR duty cycle % and ICP while cranking. Look to see if the delay is the same time period it takes to get to 500 psi. If the delay is related, you have a list of possible issues. You could have a bad pump, ipr, icp, any leak anywhere in the high pressure side from the lines to injector o-rings.
The 1st thing I would do because it's the most common is to replace the IPR o-rings.
Bob
Bob Riley, Owner DieselSite.com
Proud Sponsor of TheDieselStop.com
GOT DIESEL? call us at 888-414-3457
DIESELSITE is offline   Reply With Quote
