Diesel Forum - TheDieselStop.com - View Single Post - Drained radiator!!!
Old 11-03-2009, 01:29 PM   #3 (permalink)
boomboom
boomboom's Avatar
Make sure you flush the whole system. Pull drain plugs from engine also, you wont believe the gunk that comes out. dieselsite.com for coolant filter system should be manditory on all. But its always best to start with a clean system first. You might have to flush multiple times to get clear water though. This could save you thousands in the long run.
boomboom is offline   Reply With Quote
