Diesel Forum - TheDieselStop.com - View Single Post - First post...fuel heater question
Old 11-03-2009, 01:33 PM   #6 (permalink)
RonKZ650
I tried to unplug mine on the outside and the plastic started to break, so I thought before further damage it was safer to unplug inside. Remove the filter and get a pair of needle nose pliers and the wire pulls off easy inside to bowl.
As to your drain, I doubt there's anything wrong. What happens is the drain hose has air in it and not fuel. It takes a little priming to get things moving. Sometimes tapping on the fuel filter will get things moving. If this doesn't work, hook up a hose to the end of the drain valve tube, give a quick suck to the hose and be quick to put the hose in the drain pan because fuel will follow in 1/4 second.
1997 F350CC, 4x4, PSD Tipper pro kleenex open filter. Roggen 6" lift kit with 26" ratflex 12" offset tires. Downpipe cut and welded to adapt 3" into a 12" outlet. 12" muffler cut and adapted to 2", then a special turbo manifold from a volkswagon modified to flank out to 3" to the tail pipe. Interior from a Corvair modified by cutting 6" off the padding. Snize and snide 32gallon aux tank mounted in rear seat, rear seat relocated to bed. Bed shortened to 4ft.
RonKZ650 is offline   Reply With Quote
