Diesel Forum - TheDieselStop.com - View Single Post - Banks intercooler pipe kit
Old 11-03-2009, 01:46 PM   #19 (permalink)
302man
Does the Banks Kit require you to cut up your truck ? I know its not suppose to be much. Typically from what I have seen in Race cars....air to air coolers knock off the temperature edge off. Just so we can run a degree or two of timing. The intercooler itself will probably do more when your at highway speeds or WOT with a ton of air gushing through it. Light throttle and city driving .... a cooler ill probably hurt performance as it turns itself into a boost restriction.
97 F-250 HD 4x4, 4:10's, Crew Cab
Banks 3" down pipe, Magnaflow 4" exhaust, DIY Cold Air - open element, tripod Banks gauges, B&M trany cooler. DP Tuner-F5 4 position Chip, Turbo Blanket +2lbs more boost, BB Mod and CLEANED the fuel regulator screen ! IDM Mod - yes it works
87 Mustang Drag Radial Car - F1R - 1200HP !
302man is offline   Reply With Quote
