Diesel Forum - TheDieselStop.com - View Single Post - Replacing brake pads
Old 11-03-2009, 02:48 PM   #3 (permalink)
doczenith1
doczenith1's Avatar
My Photos: (11)
I'm no expert but if you have one out of four surfaces worn excessively I would guess that the slide pins on that caliper are not functioning properly. I would replace all the pads and lubricate the slide pins. If you don't replace all of the pads you will most likely have different friction levels on each side of the vehicle which may cause the vehicle to pull to one side.
Perhaps Jack, the resident brake expert, will chime in and set the record straight.
Al
2011 F350 Lariat, SC, SWB, 6.7L, 4x4, 3.55ELD, FX4, Lariat Int Pkg, 20's
Ordered 10/27/2010
Delivered 12/13
2003 Mustang SVT Cobra, black convertible. - 6/2007
2002 F250 Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. 12/2001 - 12/2010 - SOLD
Link: Differential Cover Spreadsheet
Link: Fuel Mileage Spreadsheet
Link: Rapid-Heat Sup Cab Heater Test Graphs
doczenith1 is offline   Reply With Quote
