Diesel Forum - TheDieselStop.com - View Single Post - Is the Tymar or Ford AIS air intake really that much better over stock?
Old 11-03-2009, 02:51 PM   #14 (permalink)
ajohansson
ajohansson's Avatar
I have the front snorkel on but did the fender sleeve mod and have no issue with the filter minder. Its not the best flow compared to the tymar but I still think I am getting good enough flow.
ajohansson is offline   Reply With Quote
