If you do attempt the 2000 grit sandpaper be sure to have a bowl of water with a little bit of dishwashing soap. Dip the sand paper in and it will help the paper glide across the surface a lot easier. I personally wouldnt attempt it with the use of an electric sander I would do it by hand.
2002 F250 7.3l Lariat
4'' MBRP turbo back straight pipe,Tymar,Superchip Flashpaq 1855,Boost,EGT,aih delete,wicked wheel
