Good point(s)!!!!!!
Of course, I suppose, once the engine is on the boost would not be at zero. Surely the turbo would be doing something.?.?.? Making some boost. Would it not?
Is there a way to check the boost at idle without the gauge? With another tool? Perhaps before the gauge but after the turbo? How about at off? To confirm if the gauge is working?
Is there a tool to connect to the OBDII plug and check the boost? How about that software that is sometimes mentioned in the threads on here?
If, when off, you disconnected the tube from the turbo to the gauge. If the gauge still read 2 pounds, for example, would that not indicate that the gauge needed adjustment? Or, replacement? But, if it dropped to zero would that not indicate that the gauge was ok?
Just asking here.
'03 Excursion, 7.3L, 4X4, Auto tranny of course (they all did), 4" MBRP exhaust, TS performance chip, K&N FIPK w/ an Amsoil EA filter, Hellwig anti-sway bar, drilled/slotted front & rear rotors. Rancho XL shocks, Rancho steering damper, Airlift 5000, S&S Diversified headlight mod. This baby surprises a lot of, so called, performance cars.
'04 F 350, extended cab, 6.0L, FX4, manual tranny, 4" MBRP exhaust, Bully Dog Triple Dog downloader w/ Outlook moniter (Very disappointed in the Bully Dog), 2m-70cm Yaesu ft-8500, S&S Diversified headlight mod.
'11 Harley-Davidson Road King Classic 103 ci PowerPak w/ anti lock brakes & Smart Security system. It even has cruise control!!! Candy Dark Root Beer over Candy Light Root Beer  Yaesu FTM-10R & a Comet CSB 790A
