Originally Posted by 302man
Does the Banks Kit require you to cut up your truck ? I know its not suppose to be much. Typically from what I have seen in Race cars....air to air coolers knock off the temperature edge off. Just so we can run a degree or two of timing. The intercooler itself will probably do more when your at highway speeds or WOT with a ton of air gushing through it. Light throttle and city driving .... a cooler ill probably hurt performance as it turns itself into a boost restriction.
I think I only had to cut out 2 or 4 spotwelds on radiator support, then again, i was using a ford intercooler and not the banks. Amount of metal removed is nothing to worry about, I had to go back and cut more out to situate the silicone boots properly.
Cooler air via the intercooler will provide a denser air charge which would make me think it would produce more power... Didn't notice any, just a bit of lag and very minimal difference in egts. I think my mileage dropped a tiny bit because heat was not aiding ignition of fuel... My truck never ran hot to begin with and it does not see much heavy towing. Perhaps a truck that works really hard would benefit having a cooler on it.
1996 PSD supercab longbed 4x4 XLT white/grey int. TS 6 position chip, New turbo w/1.00 Turbine housing  3" dp 5" exh. no cat, no muff 6" stainless slash tip. DIY Napa intake Sony Xplod stereo, door speaks, amps and subs. Autometer gauges and pod E4OD 150k miles. GEAR VENDORS! One piece rear drive shaft, two piece front shaft 4" Superlift on Weld wheels wrapped with Pro-Comp Xtremes. Clean. All rebuilt fuel system/new pump, new SD Intercooler, Modified Banks Pipe kit. **********SOLD**********
2002 Silverado 5.3 1500 2wd stock Pioneer Navi 1 daily driver 110k miles
1996 Kawasaki SXI750 twin big Mikunis factory pipe R&D head/rideplate kustom kut solas impeller ported/polished big power, little ski 58mph w/235lb rider on VP-C14
1988 Suzuki LT500 Quadzilla
1978 Suzuki FZ50
1977 Suzuki FZ50
1978 Motobecane 50V
