Diesel Forum - TheDieselStop.com - View Single Post - looking at an 04 6.0
Old 11-03-2009, 06:13 PM   #19 (permalink)
dikkstarr
dikkstarr's Avatar
Originally Posted by JAKE8842 View Post
Ticking time bomb? I dont think so. Ive seen plenty of 6.0's over the years that have been nothing but reliable. People like you are what gives this engine a bad name. Ive seen much more that have been good than i have bad. Usually the ones with problems are the people that dont give a crap and just run the wheels off of them with tuners. Even some of those still run like a top. Ive seen plenty of 6.0's with over 200k and no major problems. My buddy has a 06 with 130k and has had a bullydog on it since 30k. This truck has had the daylights kicked out of it, always on extreme mode, no maintanace done and maybe 6 oil changes done and the only problem he every had was stc fitting went bad at 50k. Sorry about your luck.
So you dont agree that of all the 6.0s out there and all the problems that arise with this engine, that it is not excessive?
Shouldnt they be a little less prone to problems and failure?
I dont think the 7.3s had this many problems.
There are a lot of superdutys out there, but I think that the "problems/failure"- "to perfect running for 200k" ratio is way off.
I bought this truck hoping that I could keep it more than 10 years because it is a diesel. I just got a little pissed when I saw coolant spraying down the drivers side of my 50,000 dollar truck. All I could think of is how can this be? I only had 14k miles. I thought our technology was more advanced than this.
Just count the TSBs for this damn thing, its ridiculous.
The 6.0l motor has surpassed Hot Chicks as the greatest Money reducing Agent known to Mankind.
2004 F-250 Lariat late build 4X4 CC/LB auto,fully loaded with sunroof, power slider and backup sensors , White with 12" ICON lift, 6 superduty valved bilsteins, flip steering, 38" MTZs on 20x12 chrome Fuel Hostage wheels, stock gears, superlift truspeed, fumoto, high idle mod, large case high amp alternator, floating traction bars, airraid intake with elbow, 4" turbo back, studded, powerslots with hawk pads, billet grill, 55 watt HIDs 6000k heads and fogs, clear corners, 7" Eclipse AVN6620BT NAV w/ back up camera, massive JL stereo 300/4 and 500/1, 2 12s behind back seat, amp research steps, sirius, '08 diff cover, redhead steering box,, coolant filter kit, hush panels and door seal mod, quad pod with boost, EGT, water temp, and fuel pressure gauges
dikkstarr is offline   Reply With Quote
