Diesel Forum - TheDieselStop.com - View Single Post - Oil rail upper seal replacement
Old 11-03-2009, 06:20 PM   #8 (permalink)
4ceFed
4ceFed's Avatar
Originally Posted by rushing97 View Post
I have an 04 f550 with 57000 miles. I have a p2290 i pressurized the HPOP and found oil rail leaking above injectors talked to ford and they said that it is a controlled leak and said probaly my injectors were bad. I pulled all 8 injectors and sent them out and tested all were good. Reassembled motor, started ran 5 mins now back to no start. has new IPR, new ICP and Harness, has 560 PSI while cranking, no start again. When running could not build over 750 PSI. - I am still searching for my answers. - Eric
HPOP, if the rails are leaking under air pressure and the injectors are good the rails should be replace as well. Leaking rails will cause erratic idle and surging, have not seen a rail cause a no start......
4ceFed is offline   Reply With Quote
