Diesel Forum - TheDieselStop.com - View Single Post - New Fuel Pump... no start ???
Old 11-03-2009, 06:33 PM   #6 (permalink)
bugman
bugman's Avatar
My Photos: (18)
Are you getting any smoke out of the tail pipe? Check all the fuses under the hood mainly #22 and #9. Also you may want to check the oil in the HPOP (high pressure oil pump) there is a plug on top of it that you can remove and see how high it is. It should be close to the top. Recheck all the plugs that may of came loose. That should keep you busy for a little while.
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline   Reply With Quote
