Did you put in a new clutch and single mass flywheel while you were at it, or did you install an old dual-mass flywheel. When a dual-mass flywheel goes bad they clatter. Can you hear the clatter just after you shut the truck off? If so, its most likely the flywheel?
"What happened to my post count? I'm a noobie again, no!"
"94 F250 4x4 Reg. cab, std., stock.
