Diesel Forum - TheDieselStop.com - View Single Post - Truck running like POO. Need help!!
Old 11-03-2009, 07:56 PM   #10 (permalink)
Patrick Feeley
Patrick Feeley's Avatar
My Photos: (19)
The oil that's in the HPOP resrvoir and rails will not drain out when you drain the oil. It's not worth it (IMO) to suck it out as the oil in the HP system will drain back to the pan and get filtered when the engine is running. There's enough new oil going in on an oil cil/filter change that it will not make much difference. Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is online now   Reply With Quote
