Originally Posted by bismic
dikkstarr -
From past posts:
You ran a tuner without head studs. You didn't install a coolant filter until after the oil cooler plugged. You run a 12" lift and you blew out a tranny hose and then the tranny failed - most likely problems were mod induced. You had a bad alternator and ran the truck while noticing starting issues - then the FICM failed. Not to even mention the unnecessary aftermarket intake.
So many things are self inflicted - many problems are avoidable.
Maybe we shouldn't have to watch these things so closely, but we do. Folks that know this up front can get a good reliable truck for reasonable dollars. This is proven. I can post links to almost ALL of the major forums where people talk about 300-400k miles as being achievable.
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Draw Tite Fold Over Gooseneck * Reese 15K Sliding 5er * Gauges Whited Out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics * Walbro GLS392 * Ford AICM * ITP Pre-pump * One Very Understanding Wife*
I AM AN AMERICAN, SO I DRIVE AMERICAN.
