Diesel Forum - TheDieselStop.com - View Single Post - Where are the ecm's in 1994 E350 7.3idi?
Old 11-03-2009, 08:54 PM   #3 (permalink)
rsr911
rsr911's Avatar
ECM's on every Ford I've ever owned where in the interior with the plug going through the firewall into the engine bay and usually on the passenger side. On my older body style 91 the ECM or TECA or PCM (pick your acronym) is in the passenger side footwell right below the inside blower housing. From the engine bay you can just see the large connector under the blower.
1986 F350 Crew Cab 2wd SRW. 1991 7.3 IDI, T-19 4spd Sterling 10.25 3.55, 12" HD clutch. A Banks waste gated turbo. 5" cut down Peterbilt stack. Midwest rebuilt IP turned up. AC Delco 6.5 GM 12V GP's, working great. Running W85 high performance zero-gel diesel! D60 front conversion, 4wd conversion, dually conversion, and steel flatbed conversion now underway. Man those frame rivets are a pain!
1966 Porsche 911. 1983 911 SC engine with modified Zenith carbs, headers, 911S brakes, custom fuel rails, MSD 6al box with timing computer, 1974 IROC body kit. 1850lbs, 200rwhp, total blast to drive.
rsr911 is offline   Reply With Quote
