I plan to start using it, I already have several gallons in my shop. First I need to use up my Stanadyne Performance Formula, I am thinking about using both the Stanadyne & the Opti Lube XPD both, just to use up the Stanadyne.
Did you notice on the test that Bio was at the top of the list for lubricity, and what a tiny percent it took? I have a Safeway near the house that sells B-20, which I could use with the Stanadyne.
My last tank was mixed with bio for about a 5% total, plus the additive Ford sells at the parts counter. My engine got SUPER quiet, people have even commented on it.
Haven't done any MPG tests yet.
Brian, Tucson, Arizona
02 F350 4x4 CREW 7.3 140K, AIS, Isspro pyro, boost & tranny temp pillar pod, Dipricol coolant temp, Isspro EV-2 Fuel Pressure & HPOP, Dieselsite boots, coolant & tranny filters & 203* Stat, 6.0 Tranny Cooler, ITP pre pump tank mod, Bellowed Up Pipes, Riffraff Frx, netbook mount with AE, GPR LED, Stancor, Battery Tender & 2 Marincos.
